Unable to get MPSCS
sdoerr2
Hello,
GRE PSR-500 radio here... got 800mhz and conventional up and going fine but I cannot get any DPD or DFD (Detroit) to work on my scanner.
I live a few blocks from Detroit (can walk there in about 60 seconds) so that should not be an issue. Using ARC500, programmed all DFD channels and DPD dispatch. It is scanning but all i get is silence. All the towers are programmed:
0867.0750
0868.5375
0868.7250
0868.9375
0867.7875
0867.1000
0868.8625
Any help here? Is there some secret setting?
nsrailfan6130
Adrian, Michigan
use the p25 Auto setting on your radio. I got the same radio you do. If you need further help, shoot me a note on my prof.
sdoerr2
Did a wildcard with Detroit towers and western wayne county freqs in... nothing. I'm wondering if the scanner is fubar
nsrailfan6130
Adrian, Michigan
The attachment I am sending should help you out. The settings are accurate so you shouldn't have much issue using mpscs. Feel free to edit out anything you won't need.
  • ARC500 Settings.zip
