Hi & welcome to the RR forums:
What scanner are you using? Were you able to hear them before? Often times hearing one group and not the other may be as simple as a disabled service type. Assuming
this system is the one you are monitoring, you'll want to make sure the Fire-Dispatch and Fire-Tac service types are turned on if your scanner allows you to do so
