ProScan: Unable to listen to Audio Stream
W8WCA
/usa/oh/cmh EM89kx
I can hear other streams on all devices
An interesting tid bit: If I set it to RSoIP and run ProScan on a laptop (Connecting via RSoIP I hear audio fine
ProScan
Software Provider
Ontario, Calif.
Also check if the audio is password protected. If clicking the audio player links on the web page then the password will be automatically sent to the player. If manually inputting the URL then the URL is like this.
http://192.168.1.11:5000/stream.m3u+mypassword
W8WCA
/usa/oh/cmh EM89kx
Good point.
URL should be like this. Substitute your computer IP address and Stream Name if different
Yes
Good point.
I just have always just used http://192.168.1.11:5000/stream
Don't forget: I have had this all running a good while now. And It just stopped a day ago
And as I said I can use the RSOIP and get audio fine
ProScan
Software Provider
Ontario, Calif.
Yes
That will work too.
No changes in ProScan in that area in a long time. Also no one else is reporting this.
Try to do more troubleshooting and find out what changed a day ago.
ProScan
Software Provider
Ontario, Calif.
FYI: I did a System restore and it all works
So some update did it not sure what update atm tough!
System Restore should be the very last resort. That's the quick way. I wish you would of double checked and triple check the setup and do more troubleshooting so we all will know know the cause. I guess we will never know.
RandyKuff
Lorain, Ohio
Correct... So now what will happen when the update installs again... Crash and burn again...
My Win 10 Pro is at version 2004... I have no issues...
ProScan was installed and running before I did the 2004 update...
ProScan
Software Provider
Ontario, Calif.
I don't suspect a Win Update nor a ProScan update caused this.
RandyKuff
Lorain, Ohio
I don't think so either...
Would be nice to know what was causing his problem though...
I don't use system restore... I create a system image before any software installs and updates...
Only takes like 5min to blow the image back using SSD's... If there is an issue...
W8WCA
/usa/oh/cmh EM89kx
I at least double maybe triple checked EVERY setting None had changed
RandyKuff
Lorain, Ohio
The restore obviously rolled back an update...
But something else had to change too...
Your guess is as good as mine as to what...
Be curious to see what the update does again when installed...
