unable to monitor Hennepin county?
mutty444
TWIN CITIES MINNESOTA
I have been able to program in Ramsey and Dakota freqs without a problem. but I cannot pick up Hennepin county. also when I ID Scan, it doesnt pick up anything on any bank, or just very seldom. so I ID search. I do not get anything from Henn CO. or any MTCO groups.. any suggestions?
Thanks. Matt.
mutty444
Hennepin county
I am using the frequencies listed under Hennepin county in the database, I have imported Minneapolis city center, North/South and Hennepin county East and West.
wogggieee
Hugo , MN
where are you located, which scanner are you using and what do you have for an antenna.
Raven95150
Nowthen, MN
In SSP you might be a little out of range of Hennepin with an indoor antenna. You might get better results if you put a good antenna up outside. You also could probably pick up several of the Hennepin talkgroups off the City Center, Ramsey Co, or Dakota Co systems.
mutty444
Thanks!
do you think a discone antenna on the roof would suffice? also what grade of coaxial cable would you think I need? I am also thinking of putting up a shortwave antenna too.
wogggieee
Hugo , MN
I'd say with your current setup that you're out of range. You likely need a better antenna setup to get hennipen county
