You are using an out of date browser. It may not display this or other websites correctly. You should upgrade or use an alternative browser.
RadioReference.com Forums
radiofeed only allows me to select the audio source of the control channel not the source for the voice channel.. I am using unitrunker and DSD+..
I have it setup like this..
unitrunker is set to send the digital signal from the control channel to Virtual audio cable 1
DSD+ picks up that scource and decodes it and sends the decoded voice to the High Definition Audio deice where my speakers are pluged in..
this works perfectly I can hear the decoded audio but when I try to use radiofeed to send this audio to broadcastify I am only given the options to send the control channel audio and not the decoded audio..
