underground dog fence antenna ?
Bandahill
Hi Folks
This is my first post so be gentle with me.
I have a 400 meter underground dog fence, and it is off when dog is not out in the yard, is it possible to use this fence as a Loop On The Ground antenna, by using
a double pole double throw switch, so that position A is fence when I need it for the dog, and position B is the fence when I need it for antenna.
I would have the fence loop wired to the two central terminals on the switch.
Thanks Folks
Bandahill
TAC4
Ontario, Canada 🇨🇦
Why can't you use a 100 foot long wire like the rest of us lol
LOG antennas do work. My only concern is that you forget
the switch position and dog runs away ?
I could swear someone asked that exact same question a little
while ago.
MUTNAV
It may be worthwhile to look at
Safety first, make sure no ground currents exist (addressed somewhere in that thread)
and I second the dog running away comment.
Joel
MUTNAV
Yea the whole thing seems like a bad idea. You should
scrap the whole idea.
I wholeheartedly object... If he's interested in MW/ LW it could work great, even if just a test of the idea. If you do test it, please tell us how it went.
Joel
TAC4
Ontario, Canada 🇨🇦
The dog loss is to risky. One wrong switch setting and by by
fido. Stick with a 100 foot end fed wire antenna above the ground.
Good enough for Marconi good enough for me.
MUTNAV
Fair enough...
Joel
