W4UVV
For the past 2 two years I have been documenting MOTOTRBO users and iding them. I can use DSD 1.4.1 but I now prefer DSDPlus and DMR Decode build 73.. I have opened a MOTOTRBO "can of worms" trying to understand the transmission's data structure and how to relate to other repeater users where applicable using DMR Decode. The first Capacity Plus trs I attempted to analyze is used by a taxi co.and appears possibly active only on 2 of 3 repeater licensed frequencies. But I think that cannot be true. To further complicate matters the license is to the two radio radio installer/maintainer and not the actual user. Two of the three(?) active Capacity Plus system frequencies are from two different previously MOTOTRBO licenses. It gets messy. These two confirmed frequencies are 461.5125 and 463.7875 mhz. and 100% on the comms appear to be on the two out of possibly 3 repeaters. It's like a composite Capacity Plus trs was created by "picking and pulling from two previously modified licenses since modified at that time for MOTOTRBO. None of the frequencies discussed or on a single modified license but two older separate licenses..
Between headaches trying make sense out of DMR Decode data displays below is what I have confirmed so far:
Color code = 1
461.5125 mhz is LCN 1 and LCN 2
461.7875 mhz. is LCN 5 and LCN 6
463.9625 mhz.....sounds like a Capacity Plus control channel and occasionally displays LCN3 and LCN4.
status
I suspect one of the frequencies is is a control channel on 463.9625 mhz. It acts like a control control. I never have heard any voice comms monitoring it. Again this was a frequency previously licensed under one of the previously modified one of two licenses for MOTOTRBO operation.
I use DSD PLus. I can use DSD 1.4.1 but have been using DSD Plus and DMR Decode frequently. Monitoring 463.9625 mhz. I see occasional references to LCN 3 and LCN 4., i.e, "resting on LCN 3" but do not hear any voice transmissions on any MOTOTRBO frequency. I see lots of "LCN 1 and LCN 2 but not LCN 3 and LCN 4. Searching each frequency previously licensed for MOTOTRBO operation, the inference is the 3rd voice repeater frequency is not 463.9625 mhz. If that is true then this Capacity Plus trs actually is a 4 frequency repeater/6 channel trs (1 Control Channel and 6 channel capacity and not a 3 repeater frequencies/4 channel (2 voice repeaters and 1 control channel repeater frequency..
The first of three questions. I have searched the internet and RR forums for 2 weeks+ attempting to locate a color code list of repeater color codes and their cross referenced values to specific frequencies. I don't have to know the frequency cross references but I want to know. I understand the important thing is the color codes are the for the Capacity Plus trs. Can someone please post a color code list or a link to a website where I can download the list or do screen captures?
Please do not post the MOTOTRBO mode technical specs. Please don't post the MOTOTRBO installation systems planning guide. Since I don't understand their heirarcey structured levels or purposes or context I get only headaches trying to follow the various install instructions from these two references.
What I need is a layman's basic tutorial on Capacity Plus systems and a discussion of each unique data element and how to make sense using DMR Decode to relate what data elements display in a Capacity Plus system. I don't like to second guess what is the purpose of a data element and how it relates to the system.
Second question. As mentioned 463.9625 mhz. appears to be a Capacity Plus control channel. Could it also be the missing LCN 3 and LCN 4 numbers which I so far cannot find but is displayed periodically in DMR Decode displays monitoring 463.9625 mhz.? LCN 3 and LCN 4 definitely are being used but running DMR Decode on every MOTOTRBO signal I can receive does not display any LCN 3 or LCN 4.
Third question. If 463.9625 mhz. is a control channel it cannot be a voice repeater. Could it be another frequency on 454-455 mhz. or possibly a 151-156.200 mhz.is part of the trs? No FCC license searches for 454-455 mhz. have been successful for LCN 3 and LCN 4 although I have ided a couple of users by monitoring the voice traffic. All have been LCN 1 and LCN 2 so far. So far I have not heard any MOTOTRBO signals on high vhf and only from 451-455 mhz. and 460-465 mhz. None of them display LCN 3 or LCN 4 using DMR Decode..
I am in a DSD world to myself in central VA. I have to rely on RR forum posts. I don't think I have done anything wrong so far. MOTOTRBO systems are here to stay and increasing in this area and statewide.. My reception range is quite good using my tower mounted pre-amped Scantennas. I would like to better understand the Capacity Plus's data element's purposes (not to the bit level but to the idiot level) signals and trs organization data element structures.
Tnx.
John
W4UVV
Color code = 1
status
Tnx.
John
W4UVV
