understanding subfleets
johnnybravo
Motorola Type I system
when you are required to put subfleets in
for example New Britain CT
System Fleetmap
Type B0 B1 B2 B3 B4 B5 B6 B7
Mot D D D D D D M M
TT S4 S4 S4 S4 S4 S4 S12 S12
what is the value I input in the Raido.... Is is the S4 value or is it just 4, or is it B0-S4 can someone give me an example. Even better does someone have a configuration for a 396T I can use
cg
Connecticut
if you choose the preset fleetmap E1P3, that is what is listed for NB. I cannot pickup thier system so I cannot verify it. I am sure the manual shows how to use the preset maps.
I have reason to suspect it is not accurate but if you hear what you need to it doesn't matter.
chris
cg
Connecticut
Does your list of PD talkgroups all match up? 600-01 thru 16? That is, are the subfleets all in the same block ? (the posted info has PD in 500, 600, and 601)
As I understand the fleet/ subfleet setup:
When you see data for NB that has both 600 and 601 it is not a S4 or S12.
Example, for the PD dispatch ID posted of 600-01, 6 is the block, 00 is the fleet and 01 is the subfleet. In the NB listing, there is also a 601-01 But with a size code of either S4 or S12, there is only 1 fleet so fleets of 00 and 01 cannot both exist.
This is why I am suspicious of the existing posted info for New Britain.
Maybe a road trip is in order.
chris
