Unication amplified charger
blackbelter
Just received my G5 replacement power amp and noticed that the power cord has 2 different sizes of chocks .Has there been a change in design ? I have not receive my G5 replacement to test the amp yet .
kruser
Well Known Member
W St Louis Cnty, MO
Mine only has one choke about in the middle size wise between your two sizes and it's located near the wall wart end only.
I'd say they are possibly sourcing the wall warts from a different vendor or did find some stray noise and specified the extra choke near the base end.
With that, I did some testing with my amplified charging base wall wart and it is very clean noise wise. I usually toss today's switching type power supplies but they have improved over the last couple years so now I test them for noise and will use them if they test clean.
Ed6698
Evansville, Indiana
I received my amplified charger base last week, it also has the small and larger choke attached to power cord.
blackbelter
Thanks for the responses, as it appears to be the new adapters . I would like to thank Ray and Unication for their quick responses in replacing my charger and upcoming G5 .
