Unication Bluetooth and F150
HandiScratchy
Charlotte NC
I'm interested in getting a pager to monitor a couple of local P25 systems. I would like to pair it to my truck's BT input. The last comments I could find here on RadioReference were from 2020 and said that Unication only implements bt to work with phones. Has anything changed since 2020? It looks like some folks have successfully paired to their vehicles. Mine is a 2015 F150.
I have a 2014 Kia and my pager will connect and play through my cars speakers just fine.
GILLIG40
Northwest, Ohio
I have a 2017 F150. The only thing that will pair with the sound system on it is a phone. I’ve tried numerous Bluetooth adapters. They will show connected but will pass no audio. I’ve given up trying to listen to my G4 in my truck. I have resorted to making up playlists with Broadcastify Calls. Then playing them on my phone Via Bluetooth to my truck.
HandiScratchy
Charlotte NC
I've had a similar result with my yaesu so I guess the issue is the Ford sync system not the pager?
belvdr
No longer interested in living
It seems to be an issue with the newer Bluetooth in cars trying to connect to the older Bluetooth 2.0 in the devices. This is the one spot of the Gx series that is annoying. It would be great if a headphone jack existed; I used the one on the Minitor 2 all the time back in the day.
HandiScratchy
Charlotte NC
The size of a g5 vs an SDS100 on my dash and the idea of running audio to the truck via Bluetooth were 2 of the reasons I was considering the pager.
GILLIG40
Northwest, Ohio
My F150 has no aux input jack. So if you are going to try and connect a SDS100 via a Bluetooth transmitter it’s probably not going to work. I tried to set up my SDS 200 in my truck with both a 5.0 and a 5.2 Bluetooth transmitters. Same as the G4 will show connected but will not pass audio. My 2012 Escape behaves the same way.
picscan
CA
Yep, tried my wife's 2015 Escape, pairs fine but no sound
HandiScratchy
Charlotte NC
My 2015 has an aux input and I sometimes run my 436 to that. The 436 is big but stays in a ram xgrip I have setup on a builtright industries dash mount. I don't think that system would hold an sds100 due to the battery size and the overall shape.
@GILLIG40 Where did you mount the sds200?
There's no good mounting location in my truck. I put the yaesu body in the console and the head is on that dash mount. cables are routed through the trim into the dash. Had to drill a few holes but it's a clean install. @JoeBearcat how about a detachable face on the next gen SDS200?
kcscan6
My devices will pair with my Jeep's bluetooth, but it doesn't work worth a damn. Anytime audio tries to pass, the screen thinks it's an incoming phone call. It has an older Uconnect system so that's probably the issue.
