Unication encryption load software
N4VGW
Rustburg, Virginia
Open your Encryption Utility-
Go to the settings Tab-You'll see "After clicking Generate Key Table Button, Options for Key Generation Are:
Select Option 4
Key In Single 256 Bit Key
Select Save
Go back to the Encryption Key table screen
Select your device
Select Generate Key Table
Now you can enter your Single AES Key
Then Program to device
Took me a while to figure it out as well.
pontotocg4
Where do you get the encryption key loader. I have the encryption key for my local Highway patrol for there dispatch channel I'm authorized to use it but need to know how to use it. I have the programming software that I use to program my pager .is that what I use to enter it.
N6ML
Your dealer should be able to help you.
IAmSixNine
Dallas, TX
Is your google broke? If not, it should be able to help you find it.
Since your being so helpful, how do you fix a broken google? can you google that and let us know.
See now my comment is as worthless as yours. But I will add info to try to help the original poster.
To enter an encryption key requires different software than the PPS software. N6ML is spot on with him suggesting you contact your dealer to have them send you the key loading software.
tkowalik
Banned
The encryption key loader is available by doing a simple google search.
Is that more helpful?
N6ML
Evidently my Google is (also) broken, then, because I'm not finding it.
I'm fairly sure that it's not generally available for download on any open website. If there is a version floating around somewhere, I imagine it's unofficial. Using unofficial software with security-sensitive keys seems like it'd be ill-advised.
tkowalik
Banned
I must have some other version of google because I just found it — second result.
You may be confused on the software; it doesn’t contain anything sensitive. You have to know the 64bit key to generate a table to upload into the pager. Unless you know the 64bit key, the software is useless.
N6ML
I guess so
It contains something sensitive as soon as you type/paste something sensitive into it. If you don't know where that software came from, you don't know what's it might do with data that you enter.
tkowalik
Banned
If you have sensitive keys to an encrypted system, the software to load those keys and the keys themselves should never be on a computer connected to the internet. Therefore, what the software does with the data is irrelevant since it can’t send any information anywhere.
tkowalik
Banned
Perhaps you'd like to share all the links you found?
There is a lengthy notice about software on this site so I will decline sharing anything.
The best way to obtain the software is to contact Unication or a radio shop. I was merely pointing out that it is ‘out there.’
I apologize that a tongue-in-cheek, sarcastic comment about a broke google turned into this.
AK9R
Super Moderator
Central Indiana
Looks like the original question has been answered.
