Unication G series use NAC for P25 Trunking
Robertolson
Long Beach ca,
In (conventional P25) I see the (NAC settings ) those channels are running spot on
My Local (1 site P25 system) is always out of Range on my G5, My SDS 100 with Stock Antenna receives it spot on.
I suspect a program Issue, as I moved though out my city with same issue.
Importing From RR, I verified All settings - Frequency‘s - WACN ID - System ID.
With The G5 in Diagnostics mode it’s showing NAC 1121, should be NAC 921
just Trying to Rule out Program Error
My Understanding is The G5 will always lock on a CC unlike, The Uniden SDS will always Scans for a CC
Maybe No NAC for P25 Trunking For The Unication’s ?
KevinC
The big K
Super Moderator
1 point
You can't have a NAC in hex of 1121, a NAC is only 3 digits in hex.
Is it showing Hex or Decimal when it shows 1121? Is the 921 the system ID or the site NAC, they aren't the same.
Correct G5 will lock on to the strongest CC, which may not always be closest or one you want. G5 also does not require a NAC per site, it looks for the system ID in the CC data.
Robertolson
Long Beach ca,
The ffff in the PPS as pictured ….did The Trick ….. hurray…..The Signal Strength Bar is like a Xmas Tree .lol
What would cause this? …..Thanks All
Does This ffff only work on a one site system, as I tried it on a multi site system and The PPS gave Me a Error message.
If you are using 4 Fs that is not correct, WACN is 5 and SysID is 3, RFFS and Site are both 2...
P25 Trunking System Setting
  • The WACN ID can be set to 'FFFFF' which means pager can automatically search and match a appropriate WACN ID to use.
  • The System ID can be set to 'FFF' which means pager can automatically search and match a appropriate System ID to use.
  • The RFSS ID can be set to 'FF' which means pager can automatically search and match a appropriate RFSS ID to use.
  • The Site ID can be set to 'FF' which means pager can automatically search and match a appropriate Site ID to use.
Robertolson
Long Beach ca,
Thanks Raleigh, I will keep playing with it ….Only owned The G5 for a week now ….My main issue of my local system is solved.
as I was getting a p25 system 70 miles away with the G5….. but Nothing on my local system 5 miles away.
One week of head scratching.
Not a problem, I would recommend only using wildcards (F) for site and RFFS, make sure you are entering the correct WACN and SysID to avoid possible contamination from another system
kb9klc
Do you need to enable Full spectrum scan to do this or, will it automatically look for any site it can find if you enter the WACN ID and System ID as intended then use FF and FF for RFSS ID and Site ID without enabling Full spectrum scan?
You do NOT need to be in Full Spectrum scan, however if you are not in FSS it will only check the frequencies for the site(s) entered.
