Unication G2 question , loud beep on p25 conventional
BITT211
ELMA , N.Y
anyone know fix for very loud beep when the screen shows , TO [ALL] , otherwise receives just fine. set up -uhf - p25 conventional , nac f86 , . populating the p25 tgid column , using wildcard hex number . is there any way that i can delete to - TO [ALL] on screen and put different tgid in to get rid of loud beep when the screen hits that ,TO [ALL]. contacted unication , they are know about problem , working on update to fix
N6ML
do you have any alerts set on the talk group ? Also I find that Talk group 1 works well
We've been over this a few times already (Seeking help for 2 issues I’m having.). Apparently Unication is working on a fix so these system calls won't generate alerts.
Meanwhile, I might try adjusting the "Tone Volume Setting" values (under "Pager Configuration Setting" for the profile in PPS. One of those might be pertinent, at least to make it less obnoxious.
