Unication G2 Scan - P25 Conventional
firemedic834
Asking for some guidance, with scanning two P25 conventional frequencies. The frequencies are each set to a single knob position and receive radio traffic with no problem. I assigned the frequencies to the same knob position with the receiving mode set to normal scan. I'm unable to receive on either frequency when the pager is set to the knob position programmed for normal scan. What did I miss?
tweiss3
Is it time for Coffee?
Ohio
You need to use 3 knob positions, 1 for each frequency, and the 3rd is normal scan with both knobs in the list.
firemedic834
Right, that is how it is programmed. Each frequency is set its own knob position. The third knob position is set to normal scan with both knob positions in the list. It doesn't receive radio traffic on either when on the scan knob.
firemedic834
Does anybody have anything else to share about this? There seems to be a missing step in the set-up somewhere. If both P25 conventional frequencies receive individually on a knob position, why do they not receive when combined to a scan list on a knob position?
brndnstffrd
CT
If you still didn't find a solution to this, if you want to send me your codeplug I can take a look at it for you and see if I see anything.
Are you using same or different NAC and TGs, what about same or different Group List?
