One thing I noticed pretty early after receiving my Unication G3 for 450-520mhz is that reception was pretty spotty on frequencies 10-15 miles away that my Uniden SDS 100 picked up rather consistently. I had found the SDS to be a weak receiver in that band and was hoping for improved coverage. Then i discovered that my G3 was experiencing severe cell site interference on that band within about 2000 feet of most cell towers rendering the device useless in these areas except for very strong uhf signals. While it was most present on 500-508mhz frequencies that I monitor from about 10-15 miles out, it would still show up to a lesser degree on channels in the 450-460mhz range. It also seems to overload on nearby UHF transmitters. Here in the Northeast US near Philadelphia it is a signal saturated area. The unit came with a green band antenna marked 450-520 so just for experimentation i switched that antenna out for a Unication 400-470 green band antenna. While some of the cell site interference was reduced but still present, the overall signal strength of desired frequencies was reduced pretty much across the board, even 450 and 460mhz frequencies. With the exception of its performance in my house where I live in a bowl surrounded by trees and higher elevations, i am rather disappointed with the performance of my G3. Has anyone experienced this? Are there any suggestions or remedies?
