unication g4/5 questions
W4ZMJ
South Carolina
#1
dose the pager have a squelch settings? and what about 800mhz rssi there a threshold setting that can be adjusted also you can add up to 64 zones but 8 channel selector im guessing you can adjusts the zones in a menu
