Unication G4/G5 Firmware 1.2 released!
alpha2disp
Have the pager store the pages, and see if there is something new. If you change into a "push to listen" mode, the pager will give you an "unread message" notification.
We are already doing that. I’m not a fan. Looking for similar operation as we had with our Minitor pagers and have an LED lit up on the unit. But thanks for the suggestion.
krokus
Southeastern Michigan
Are your pages coming in on a specific, and separate, TG than the other radio traffic? MPSCS calls them PageGroups, to differentiate from regular TG.
Sent using Tapatalk
alpha2disp
Sent using Tapatalk
So I have two groups of alerting channels. One dispatch center is done by TGID only, with all other radio traffic on a different TG. The other dispatch center is sending 2 tone over the same TG as the radio traffic. Alerting is not an issue, and I have the correct items in the Revert group.
APX8000
Sarcastic Member
AES-256 secured
Was wondering if there was any info on if there is another firmware update in the works and if so what might be the issues if any being addressed or features being added.
This has been asked and answered weekly.
mdsxfire
EDBM
Uxbridge, north of the river Thames
I think this has already been addressed, but I just want to clarify before I install the update...
I have the G5 and used the utility to change the model number so I could receive DMR.
What affect will this firmware update have? Will I still be able to receive DMR? Will I need to change the model number back to do the update? Will I need to change the model number again in order to receive DMR?
I want to install the firmware update, but I don’t want to lose DMR.
Thanks!!
What utility did you use to change the model number and where can I get it?? Thanks
N6ML
There was a PDF document describing how to do it on the Unication download page, and it linked to a dropbox containing the "Function Updater" utility. It appears that both have been removed. Your dealer should be able to get you copies. If that doesn't work, let me know.
krokus
Anyone else seeing a discrepancy radio ID, on P25 systems?
My pager has been showing incorrect radio IDs for in-county units, on MPSCS.
Sent using Tapatalk
N6ML
It's a well-known issue, going back at least a couple of firmware versions.
