Unication G4 intermittent issue
iloverf
Houston, TX
Sometimes I turn my Unication G4 on without watching it boot up and making sure it comes up normally, gets signal and starts scanning - and I'll notice minutes later after hearing no traffic that the screen is blank - even though it's powered on. Pretty sure I've tried mashing a few buttons to see if it wakes the radio/screen up but usually just end up turning it off and back on again - this usually resolves the issue. It could be the radio is doing something it's meant to do or misconfigured to do and I just don't recognize what's happening... Sound familiar to anyone? Any suggestions for something to push/do besides power cycling it next time it happens?
JoeyC
Senior Member
San Diego, CA
Yes, it happens to mine from time to time. It always comes back after a restart so I haven't been concerned. Maybe I should?
picscan
CA
I sent mine in, when I would change the channel it would go through the re-boot, the joystick went out on mine too. The other day I turned mine off but it would not turn off, I had to pull the battery. Good thing they have a 5 year warranty.
JoeyC
Senior Member
San Diego, CA
I have not had any of that happen to mine, but just as iloverf described, I turn mine on and occasionally (maybe once every 20 turnons) it will do nothing. Usually you can change the channel knob, or push a button and the screen will light up and you can be assured all is well, but not when this happens, it is just dark and non responsive. Turning off and back on things have always (so far) returned to normal operation for me.
ka9rxk
My G5 VHF does the same thing. I turn it on, after a while realize I haven't heard anything, and then check to see that it is dead. I then trun it off and back on and it works again.
I then laugh to myself because everyone out here keeps reminding us that this is a "professional radio." My Motorola APX8000XE turns on 100% of the time. Come to think of it . . . .so does my Baofeng.
It's amazing what we're willing to put up with for the small form factor and excellent receive!
bob550
Albany County, NY
Due to their sophistication, I'm sure intermittent glitches will occur. It's when those glitches become common among users and repetitive that it's worth investigating. Case in point, just last night I powered my G5 up while it was on knob position 1. Instead, it displayed the contents of position 6. That's the first time it's done that, and so I'm not going to worry. I just toggled the knob to display the proper programming instead. Now, if that happens again, I'll simply reload the code plug.
blackbelter
My G5 behaves the same . Occasionally after charging the unit the screen goes blank and I simply turn the unit off and back on again. I communicated this with my dealer and he mentioned that this sounds like the processor and I can sent it in or reload the FW if continues . I will wait for the 1.3 and decide .
RBMTS
Strange, I've never had that happen with my G5. I wonder if it could be something with the codeplug profile. I know that some people are excited to get their new Gx pager and prebuild a codeplug. Possibly they selected the wrong model number in the drop-down box in the PPS?? Example they selected and programmed (and ultimately uploaded) a codeplug based on a xx-1400 and their true model is a xx-1401 ?
When my G5 arrived, I downloaded the codeplug from the radio (and saved a copy). I then programmed in all of my settings into that original codeplug and then uploaded it. Again, never had a problem with it locking up, feature not working correctly, etc. Guess I'm just lucky.
AdamHLG
This is exactly what I did and also what I did for the other radio's I programmed for folks. I too, however, have noticed that once in a blue moon I will get the silent treatment, and turning it off and on fixes it. Another bizarre issue that happened twice in one month - so very very intermittent - is that I will hear a random police talk group when scanning 10 programmed FD talk groups. Not sure what's up with that but it goes away just as quickly as it appears and I do not even need to restart the radio. Neither of these issues really bug me at all as I still love this radio.
JoeyC
Senior Member
San Diego, CA
Oddly enough this just happened to mine. I turned it on and before it had fully booted up I turned the selector knob from position 8 to 1 and attempted to change the zone before the radio was ready. The unit stayed dark because of this. I'm thinking this is why my unit stops responding.
Floridarailfanning
East Tennessee
I have experienced most of these issues with my G4 and numerous others over the last 2 years. I really like the G4 in terms of P25 RX performance, but Unication needs to get it together. These pagers are advertised as "Mission Critical" public safety devices, so unless Unication has a vastly different definition for mission-critical, they have a long way to go. Reliability should be just as important as functionality.
winstonsf
I had a new unit that would not turn on after turning it on. This would happen intermittently, maybe 1 out of 10 turn on’s. A replacement unit did not have this problem but it did reboot itself once in the middle of operating.
iloverf
Houston, TX
I assume I need to wait for the problem to occur again after enabling the Trace Log functions per the .pdf to make sure relevant logs are included when I attempt to extract/upload?
Uni1
Unication Representative
DFW Texas
Yes. When you see any issue, hold the smaller side button until you see the message "save log end". After you saved the log it can be uploaded whenever convenient.
JoeyC
Senior Member
San Diego, CA
I just tried to "save log end" but because the screen is black and the unit is unresponsive, nothing happens. Was there a save that I didn't see?
In addition, from the Function Status page, I have only 3 options on 3 pages, not 5 as per the instructions you sent:
1. Select Zone
2. Bluetooth settings
3. Monitor mode (greyed out)
Uni1
DFW Texas
1. Select Zone
What firmware version is in your pager?
