Unication G4 Knob Question - Am I Doing This Right?
MDScanFan
USA
I will say up front my terminology is likely wrong on this but here goes...
I programmed my G4 for several different talk groups. I have a different talk group programmed into the first six knob positions. Everything is working fine. When I switch to a different knob position I need to then select Z/C and select the corresponding zone list item and then select Save. This seems like more steps than it needs to be. Am I doing this correctly? It seems like I should be able to just change the knob position and the corresponding talk group would come up automatically without having to navigate into the menu.
N6ML
SF Bay / Delta, CA
If you only have six knob positions to deal with, you don't need to change zone. You should program all of them in the first zone - i.e. in a single row in PPS. It sounds like you may have programmed knob position one in each of six different zones, or something?
MDScanFan
USA
I follow what you are saying. I will take a look at the PPS and see if I can make this change. Thank you.
MDScanFan
USA
That did the trick. Thanks!
