Early testing is promising. The false positives stopped this is very nice development. There was a fire box today and while 'alternate' was 'enabled' it did seem to alert because it started recording but the alert tone I was expecting to hear seemed like a blip of a sound instead. This too was a positive development.
I am curious if the alert tone, when triggered by the warble, will play the selected alert tone to completion, or does it only play for the same duration of the warble. In other words, in your Step 2 (Tab 4) above, I am using Tone 5. I am wondering if the G5 will play tone 5 in its entirety, or will the duration of Tone 5 cut off early if the warble is shorter. Maybe this is why I only heard a short blip of Tone 5 when the warble was received.
I note that under Tab 7 (Pager Configuration), I have both the Receiving Alert Tone Volume and the Notification Tone Volume set to "By Volume Knob" if that matters. But it was a comfortable volume to hear the call so that's probably not it.
I also note that under Tab 7 (Pager Configuration), under "Receiving Alert Mode Setting", the setting "2-Tone Alert Duration Type" is set to "By Tone". I am wondering if the phrase "By Tone" sets this to the duration of the warble - and maybe that is the issue. Maybe I should set that to "Fixed Duration" and make it "2 seconds" which is the duration of Tone 5. Does this make sense?
All of the above is qualified by the fact that there was only one warble tone today. Some of these questions I can answer myself by playing around after there are future warbles to trigger things.
I'll follow up as I continue to test. This thread has been very helpful - - much appreciated.
