Unication G5 amplified charger questions
minasha
NYC
If I buy an amplified charger for my G5 will:
1- I be able to listen at the same time it charges?
2- If I plug in the cable from roof antenna to the antenna jack will it bypass the pager's small antenna and give me the improved reception from the roof antenna?
3- I have read about audio popping sounds when using the amp/ charger any recomendations on curbing that.
Thank You
Synchro39
Saint-Zotique,Quebec
yes you would be able to listen and charge at same time
yes if you connect external antenna you will get better reception
i have this amp charger and no popping sounds for me it work great since the last firmware update
ed3750
Palm Beach County, FL
1-Yes
2-Yes, on both bands. I use an external UHF antenna which improves UHF reception and doesn't appear to degrade my strong 800mhz signal.
3-I have two amp charges and have never experienced popping sounds
minasha
NYC
1-Yes
That's great news thank you
Peerlessk
Lima NY
I do all the above with zero issues . The amp charger works as intended flawlessly
