Unication G5 and Pairing Apple Airpods over Bluetooth
blackbelter
I also have not been able to pair up with my new Apple AirPods 3rd generation with noise cancelling feature .
mitbr
Tampa Bay Florida
The BT version on the info screen seems to make no difference. Both my G4 and G5 show BT ver 2.0 but both pair with the VR3 speaker from Home Depot which states it uses BT 4.2. So the problem with the Apple buds must be specific to them and not the BT vers.
Tim :cool:
N6ML
It's not quite that simple. From what I understand; BT 4.x can be backwards compatible with older BT versions, *if* it's using the older BD/EDR protocols, but the newer BLE protocol is only implemented in 4.x. Presumably the devices that work with the Gx BT2.x (such as your VR3 speaker) are not using BLE.
mitbr
Tampa Bay Florida
Assuming that is so why would the Apple ear pods not work looks like they use bt ver 4.2 any ideas?
Tim
blackbelter
It really be beneficial if we can post a list of proven BT headsets to pair with G5 ( Not BT speakers ).
Thanks in advance
picscan
CA
LG HBS-750 works
Plantronics M165 bluetooth phone earpiece works too although volume is pretty low, I think it's because the rubber cover on the speaker is torn and won't fully seat in my ear, it gets way louder pressing it into the ear. You have to turn the G5 up to around 80 to hear it halfway decently. I like this one because it's small and only in one ear.
blackbelter
Has anyone tried these Unication BT headsets and paired successfully ? How’s the sound ?
blackbelter
I have also purchased the Unication BT130 head set and very disappointed with its audio quality. Will return to unication.
hummin24
SO RI
I'll mirror what others have said. My G5 won't pair with AirPods, my PrimeBlue RSM, Bose Sound Link- the only thing I have successfully paired with is a Plantronics Explorer 110. However, while using it with the 110, the G5 reset several times,(for seemingly no particular reason). I gave up on using BT.
Same
hummin24
SO RI
The Bluetooth on these devices is pretty much useless even if you do find a speaker system that is compatible it always seems to time out and have to reset itself the volume isn’t loud enough to hear anything anyways don’t waste your time
blackbelter
How are those SSM-BT 10 sounds ?
I ended up returning the Unication BT head set back for poor and low sound .
Hit_Factor
Saint Joseph, MI
I have tinnitus in both ears, so I go with simply can i understand what's said? Yes, I can. Now that you mention it, I have tried to turn up the volume past 100% for my 'bad' ear.
I prefer the Icom with a Secret Service style earpiece. These can be used with hearing protection and without, just change earbud out.
MonitoringDelCo
Has anyone tried a Micro USB to 3.5mm female audio adapter to obtain audio from the Micro USB port for wired headphones?
