Unication G5 Antenna For 800 Mhz Band
JASII
Memory Capacity
In the past , I seem to recall some posts about after-market antennas for the Unication G5 that are resonant on the 800 Mhz band. I do recall trying my Motorola DTR550 long whip antenna and I seemed to notice an improvement. At the time, I didn't need the additional gain and I sold my DTR550s. Now, however, I could benefit from having an antenna with a bit more gain on 800 MHz. What are some of the better choices right now for antennas that get a bit more signal than the OEM Unication antenna?
Mine is the original antenna, too. If I recall correctly, there is a somewhat newer OEM Unication antenna that might perform better than the original OEM antenna.
PapaG
WB4IAR
Hoover, AL 35226
I have a SMA female to BNC female adapter on my G5 and use the Remtronix 800 antenna. It receives very well.
RBMTS
JASII - be very careful if you decide to put a third party antenna on the G5. Search on past posts about antennas. Look at the pictures. If you don’t use the correct style connector you will end up pushing the pin down into the radio. This can cause the OEM antenna to no longer work. Users have also stated the pin breaks off and gets pulled out by the third party antenna.
Just ask yourself if a little gain is worth risking a $600 radio.
Johnnydollar2
IL
This has been covered many times in the (SEARCH) box in RREF. Here's a thread complete with links to favored antennas and arguing galore.
Here's what I use
bob550
Albany County, NY
I'll second that! Just make sure the adapter's SMA connector is the same as the OEM. Although currently unavailable, this is the adapter I purchased a year ago, and I've had no trouble with the center pin on my G5. I also use the Remtronix (RadioShack) 800 antenna with very positive results. Here's another adapter I purchased that also works.
nosoup4u
High Bridge, NJ
How is the gap between those 2 adapters and the pager? I have one that I bought years ago for a Motorola radio but there is a good 1/4" gap on it.
radio3353
There is no gap with the ExpertPower adapter.
Are you sure? From ths pictures on the Amazon page it looks to me like the SMA female jack is recessed into the connector. That is why it will work (i.e. not push the male pin down.) Or, are you talking about something else?
bob550
Albany County, NY
Expert Power adapter:
Custom Cables adapter:
The SMA connectors on both adapters are recessed 2MM, as is the OEM antenna. Neither should place undue stress on the G5 pin.
minasha
NYC
with the expert adapter and Radio Shack 800mhz antenna is there any real gain over the OEM antenna?
eorange
♦Winner of the 2021 RR Forum Achievement Award ♦
Cleveland, OH
In my experience...not by much. The only thing it helps is pulling in a fringe system (Parma), but barely, which is interesting. But otherwise no improvement over stock with MARCS or GCRCN.
