Unication G5 Antenna For 800 Mhz Band
jonwienke
More Info Coming Soon!
VA
I use BNC antennas, and adapters on each radio correctly fitted to the host. It eliminates fitment headaches and makes it possible to choose antennas solely by frequency range, instead of having to worry about which antenna fits where.
bob550
Albany County, NY
The use of an BNC adapter for using different antennas would certainly make sense for the SDS100's due to their wide frequency coverage. It's not so necessary for the G5. That said, the one advantage to the BNC adapter is that it facilitates the connection of an external antenna if desired. But again, I don't find that necessary. Anyway, even with the low profile adapter I was using, I never liked the "Frankenstein" look it gave me. :)
bob550
Albany County, NY
It eliminates the worries re the center pin.
I was curious about the depth of the recessed center connector on the Kenwood and so I measured it using a tire tread gauge (Yes, I know. It's not the most scientific method to use, but it's better than guessing. :)) The depth is identical to both the Unication antenna SMA as well as the BNC adapter I use.
bob550
Albany County, NY
Unfortunately not. I apparently enjoyed spending $28 more, including a steep shipping charge, through a different retailer. :cry:
JASII
Memory Capacity
Have you compared it to a Motorola?
I assume the measurement are different?
N6ML
The Motorola that I've played with has no recess at all. I'm not sure that it's actually genuine Motorola ("eBay special"), but I imagine that the dimensions are at least similar to a genuine one.
WX4JCW
Stow, Ohio
I have to second that, if you want to send the radio back for repair possibly use a Motorola antenna, I didn't listen and used one, but I was able to recover
blackbelter
I am in deep coverage thus the Unication stubby antenna works great for me . In event that I would need an extra signal , I use the amplified charger with the RS antenna connected. Works great .
bdp278
New Orleans, La
It appears my third party antenna pushed in the pin in the antenna connection now my OEM antenna will not work. Any way for me to repair, maybe trying to pull the pin back up, or send in for factory repair?
bob550
Albany County, NY
It would be helpful if we knew what brand/model of antenna this was so that others can beware.
WX4JCW
Stow, Ohio
use tiny needle nose pliers and be very very careful, I used the signal diagnostics to position the pin in what I hoped was the right spot
GTO_04
Noblesville, IN
So, I picked up the Kenwood KRA-32K 700/800 MHz antenna, trimmed the skirt as needed, and find that it performs on a par with the Remtronix/RS 800 antenna I had been using with an adapter. It also looks like it was made for the G5.
I just received one these. About how much did you have to trim from the skirt to make it fit?
GTO_04
