Hit_Factor
That's a good model, pay for what you need, not for everything you don't need.So Unication is now employing the Uniden model of charging an upgrade fee?
Very much like ordering a new vehicle. Not everyone needs a tow package.
So not to start yet another similar dmr thread just yet , I thought I'd ask about how to enable dmr on a new g5b66bf that came with firmware 1.2 and using pps 3.14.15. I have combed through many threads/posts about this but a lot of yay's/nay's and such on this, plus varying answers depending on when the info was posted. Best I can surmise is to "copy from existing profile" then "convert new model" and select g5b67bf as the radio (dmr now shows up as a choice under protocol type) and it would change the model and accept it when writing to pager. My hang up is when I get ready to write to the pager I get the following popup, "The device does NOT support: 1. Protocol (dmr). You can still program anyway but the data which device does not support will be removed." So where am I going wrong? How do you actually change the model number on the pager to the 67 version? I thought the pps program would do this for you in this particular instance.
Thanks Sly
Just got a G3, DMR is included
I just received a used G5, it's a 66 model and it lets me program DMR channels.
Thanks for the reply, but that kinda stinks. When was this utility removed for end user? Must've been pretty recent. I've also read some threads on here from not that long ago about people re-flashing 1.2 on their own pager to fix corruption issues and strange behavior. I can only assume these folks must have been able to download and store a copy of the 1.2 f/w and the flash utility before it all got yanked. At this time you apparently cannot download firmware off the unication site, only sign up for an alert if there's an update.As far as I know, you have to send it Unication to get the model number updated (for a small fee). There was a utility that did it for free download for a short time, but it was withdrawn - I assume due to licensing. Contact your dealer for details.
I'd like to know too. Which version of pps and what firmware version yours has?You sure about that? What version of PPS? What model have you selected for the profile in PPS? If I create a profile for, say, G5B66BF, DMR is not even presented as an option on tab D3.
3.14.15 and firmware is 1.2You sure about that? What version of PPS? What model have you selected for the profile in PPS? If I create a profile for, say, G5B66BF, DMR is not even presented as an option on tab D3.
Rgr that, thanks for all the info. Sometimes really hard to filter thru all the info posted on here to find out what you really need to know.I know it (more detail on "it" below) was available for download in March of this year, but only for a few weeks, from what I recall.
Updating firmware is a separate process from enabling DMR. You should still be able to update firmware via Downloads- G4/G5 P25 Voice Pager | unicationusa if you need to - I just tried it (entered my serial number), and it offered a download link.
DMR is a *feature* in the firmware, which is enabled or disabled based on the model number programmed into the pager. If it's 66 or lower, DMR is disabled (even though the code is in the firmware). If you have a model 67 (or perhaps higher in the future), DMR is enabled. There was a tool called "FeatureUpdater" that was available for download in March - the purpose of that tool was to change the model number to 67 (not to load different firmware). The tool was withdrawn, and owners advised to contact their delears about sending their pagers back to Unication to get DMR enabled. It's presumed to be due to a necessary license fee that must be recovered.
