Unication G5 loses programming temporarily
firemun
Concord NC
After having great a great experience with my G5 for a couple years now, it has randomly started flaking out. The pager will just randomly go silent. When it does this the display shows it is still scanning however, there is no receive signal strength displayed nor is there an out of range error. All three lights on top light up red. I can cycle the power and it doesn’t help. I can reisntall the program and it works fine until the next time it flakes out. It does this on different P25 systems. I live in a signal saturated area and the scanner will lock and recieve with the antnenna removed so it is not an intermittent signal issue. I have created a new pps file and it does the same with the new file installed. I have the latest firmware. Any thoughts?
Uni1
Unication Representative
DFW Texas
Sounds like you battery is bad. Try pulling out the battery and replacing it to reset the pager.
firemun
Concord NC
Just curious about this as the battery shows it charges fully and the pager will easily operate for 1-2 days. Just want to confirm before I buy a new battery. The current battery is about 7 months old.
Uni1
DFW Texas
I was going off your couple year old statement. From what you are saying the battery sounds like it is not the issue. Did you pull and replace the battery?
