Unication G5 Not Passing Audio
RESQ766
I programmed my G5 to do a Trunked TG Scan it specific talkgroups for the state’s P25 trunked system but it won’t pass any audio. It will show when someone is talking on a TG but I have to hold the reset button in order to hear the audio every time even though it is not programmed for press for voice. I also tried changing it to Trunked TG monitor but I still have the same issue. Anybody know how I can fix this issue?
blackbelter
Set pager to " on Duty " , also under main menu scroll down to "function settings. Then scroll to 2. Receive Alert Mode. Select "Tone".
N6ML
The usual cause of this is setting "Alert Mode" to "Silent" for the knob position. You might have done this because you don't want an alert tone, but it doesn't work that way. If you want no alert tone, you should set "Alert Mode" for the knob position (tab D5 in PPS) to "Tone" and for the talkgroup (tab D4) set either "Alert Mode" or "Alert Tone" to "None" (or both). It's not very intuitive, but that's how it is.
Also check that "Push to Listen" is not selected for the knob position.
RESQ766
Thank you so much guys! Changing the revive alert mode to tone and setting the pager to on duty did the trick.
