Unication G5 Pager TGID Removed
dbruce0571
I have a couple of pagers that at random times will flash a green banner at the bottom of the display the say TGID Removed. When this happens, the pager has no audio. These guys have missed calls because they didn't know it went into this mode. The only way I have found to reset it is by taking the battery out. They are all on the same firmware. These pagers are less than a year old that are doing it. Mine is 3 years old and has never done this and has the same firmware. Any ideas?
Floridarailfanning
East Tennessee
In the programming software go to tab D then section 8 and there should be an option for TGID Hold and TGID Remove. Make sure they are both unchecked. This will disable the remove and hold function so the guys won't miss anymore calls.
dbruce0571
I believe you are correct. I was able to duplicate it with mine. How do you get it out of Blok mode
dbruce0571
Thanks. I had just tried that. I think I will remove the Blok soft key from the pager. I really don't have a need for it. I use the hold quite a bit, but never the Blok.
