Unication G5 Pin
Synchro39
Montreal Quebec
I'm trying to figure out the pin outs on the bottom of the G5 i want to bypass the speaker but want to use antenna and charger and just bypass the amplified speaker
Hit_Factor
Saint Joseph, MI
Why do you think the pin out isn't valid? Same charger works with all models. Thus, same pin out.
I'd open up the charger and disconnect the two speaker leads and hook up a speaker or oscilloscope to verify signal. Go from there.
Or
Cover the speaker pin with dielectric tape, drop it in the charger. Check to see if you are getting results you seek.
Synchro39
Montreal Quebec
Or
i tried your option #2 but no sound at all from base and not from pager
Synchro39
Montreal Quebec
i presume as soon you connect it to the charger the G5 cut his sound i even try to unplug the speaker still no sound coming from the pager
radio3353
Can you simply disconnect the leads to the amplified charger"s speaker to silence it?
