cfegs
Hi,
I am getting close to purchasing a G5 and have already downloaded the PPS software and went through the software coming up with how I will program the pager. I plan on using this as a pager and scanner for my area in southern NJ. Our county uses a P25 Ph II digital trunked system for communications with the exception of FD paging which still uses our VHF dispatch frequency with 2 tone alerting. I want to monitor 2 different counties in my area but until the new firmware is released to be able to scan two different P25 systems, I have it set up as one system per knob position.
I want to ask the experts out there if this configuration below will work and then once the new scanning firmware is released, I want to program the last knob position 8 to scan the two P25 systems.
I have set up positions 1 and 2 as selective call alert on VHF, position 3 as monitor my VHF freq. Positions 4 and 5 are scanning a few TGIDs within one system separately. then position 6 scans one of the counties P25 system with 2 sites and position 7 scans the other counties P25 system with 1 site. Once the new firmware is rolled out can I set up position 8 to scan both knob positions 6 and 7 or set it up to scan both systems not by knob position.
Thanks for your input in advance.
