APX8000
Sarcastic Member
I'm trying to confirm whether or not the following is true:
For alerting over P25 trunking, the pager does not actually decode tones sent over a talkgroup. Rather, the pager simply assumes that a particular talkgroup IS the unique paging address. In other words, for each set of QCII tones you might have for the different departments within a County, you would need to create a new talkgroup for each of those departments. So that instead of the pager actually decoding QCII tones over a single talkgroup, it instead assumes that when a particular talkgroup is active, it alerts.
Most of the County Dispatch Centers setup multiple QCII tones on one frequency or ONE TALKGROUP. This is the way is also works currently with the APX Tone Signaling. Instead, the system admin would have to literally create a talkgroup for each paging resource on the console. Then instead of dispatching over a single talkgroup like it's done now, the dispatchers would have to manually select the talkgroup based on who they're toning out? So my County has over 50 fire departments each with its own set of QCII tones. I would have to create 50 new TALKGROUPS, one for each department ????
That's how the FAQ for the G4/G5 appear to read...it makes it seem like you can enter both a QCII combination AND a TGID. So naturally you'd think that it can actually decode those tones on that talkgroup...but if you try to add BOTH of those to the same Channel, it balks because the TGID is duplicated....
