Unication G5 Wild Card Scanning Blok
JASII
Memory Capacity
Since earlier this afternoon, when I upgraded to firmware V1.3, I have been monitoring a trunked system using the Wildcard Talk Group to hear all activity on the system. One of the things I was wondering about is how many lock outs (Bloks) are possible and how the Unication G5 behaves when you "hit the wall", so to speak.
I did run across this is the D8-Pager Configuration Setting-Parameter Description:
TGID Remove Setting
  • Definition
    When press "block" soft key, pager will temporary remove current talk group ID from talk group list, recovery by switch knob selector. Only available in Trunking TG-Scan mode and Trunking TG-Monitor mode. Maximum 64 TGIDs can be blocked.
What I think is happening is that once the 64th TGID is blocked, when "Blok" is selected again, it simply blocks that TGID and un-blocks the previous 1st TGID that was blocked. However, I really can't be sure. I don't know how many TGIDs are blocked at any point in time.
If anybody else here is able to test on their Unication G4/G5, I would love to hear how it works. I absolutely love this feature of the Unication G5.
