Unication Programming
JASII
Memory Capacity
One of the criticisms of the Unication G4/5 is that it is not currently possible to turn scanning off. I am just curious if anybody here is programming any of their zones with just a single talkgroup? In essence, making that zone a single channel monitor.
One of the other things that I am considering, is having different profiles in different zones with a different priority talkgroups pre-programmed. That sort of cures the problem of not being able to change the select priority talkgroup from the keypad.
One other criticism if changing from TALKGROUP SCAN to TALKGROUP SEARCH, or whatever Unication calls it, from the unit is receiving. One work around has been to remove the antenna. With so much memory available, why not program the same group of talkgroups in the next zone over and have it pre-selected is SEARCH rather than SCAN?
I would love to have Butel, or somebody else, make after market software for this similar to their software for other radios. It would be nice to be able to leave this connected to a computer and have it perform unattended monitoring.
That way it could
-Log Newly Found Talkgroups
-Log Fire Tones
Thunderknight
Bletchley Park
I have some of my knob positions as single talkgroups.
I believe to be used as a pager, that is exactly what you would do anyway.
APX8000
Sarcastic Member
AES-256 secured
Same thing here as Thunderknight. Knob position one scans "PD SCAN" which scans all the dispatch, car2car and info talkgroups. Then position 2 PD North, position 3 PD Central, 4 PD South, 5 C2C N, 6 C2C C, 7 C2C S and 8 INFO/TTY.
sparklehorse
Portland, Oregon
My programming is similar to Signal-Zero's. Besides single talkgroup knob positions, I also have additional scan lists in other zones, like one just for Fire Ops channels, one for Law Only, one for Airport ops, one for Misc Agencies. Then I have another set with my usual talkgroups, but using a completely different simulcast site. My G5 will sometimes switch to East Simulcast site when I'm in that part of town, but often it hangs on too long to the West site. So I can force it to use East Simulcast if I want.
Then I have a bunch of conventional channels and several scan lists of those in additional zones. Twelve zones in all at the moment.
IAmSixNine
Dallas, TX
I set mine up the same. Zone is a city. Then each channel either has several to scan or an individual channel.
If this catches on perhaps Unication will add a 16 channel selector, a bump up from the current 8 channel selector. But with 8 im making it work. If its a large system then i would have Fire as a zone of its own and Police as a zone then miscelaneous zone.
Either way with 8 channel positions and being able to put 1 entry or 64 TG entrys im happy with it.
prc117f
That way it could
-Log Fire Tones
I do. I have a zone with just one talk group for each channel. Acts like a regular channelized radio. I programmed it just like my work radio with exact same channel names etc.. which is a harris P7300. so now I do not have to carry that brick anymore when on call just the little G5. I have 7 channels on my P7300 and now the same on the G5.
so in essence its single channel operation.
prc117f
When a future G6 arrives it would be cool if it had a channel knob that just spins around so you can have x channels.
so if you program only 2 channels, then turning the knob around will just switch between channel1/channel2.
if you have 16 then it goes through 16.
