UNID NOAA Station
slatescan
Hendersonville,TN
at 11:08 My other scaneer with the rs indoor antinna I took it outside and got on 162.450 suddey i hear the forcast that they said was out of jackson, who is this?
INDY72
Indianapolis, IN
That would be one of the North Mississippi Towers for NWS Jackson. You got some ducting if you were over 50 miles from the transmitter... I will post the North MS tower ID's and freqs in a sec.
INDY72
Indianapolis, IN
Mississippi
Print
SITE NAME CALL SIGN FREQ WATTS NWS PROGRAMMING OFFICE
State Map Ackerman KIH51 162.475 300 JACKSON, MS Coverage Map
Map use notes Booneville KIH53 162.400 700 MEMPHIS, TN Coverage Map
Bude KIH48 162.550 400 JACKSON, MS Coverage Map
Columbia WXL21 162.400 100 JACKSON, MS Coverage Map
Gulfport KIH21 162.400 1000 NEW ORLEANS Coverage Map
Hattiesburg KIH47 162.475 1000 JACKSON, MS Coverage Map
Inverness KIH50 162.550 500 JACKSON, MS Coverage Map
Jackson KIH38 162.400 1000 JACKSON, MS Coverage Map
Kosciusko WWG38 162.425 100 JACKSON, MS Coverage Map
Leakesville WNG640 162.425 1000 MOBILE, AL Coverage Map
Meridian KIH49 162.550 1000 JACKSON, MS Coverage Map
Oxford KIH52 162.550 400 MEMPHIS, TN Coverage Map
Parchman WWG37 162.500 100 JACKSON, MS
INDY72
Indianapolis, IN
Tennessee
State Map Bristol
WXK47 162.550 500 KNOXVILLE/TRICITIES, TN Coverage Map
Map use notes Centerville KWN53 162.450 300 NASHVILLE, TN Coverage Map
Chattanooga WXK48 162.550 1000 KNOXVILLE/TRICITIES, TN Coverage Map
Clarksville WWH37 162.500 300 NASHVILLE, TN Coverage Map
Cookeville WXK61 162.400 200 NASHVILLE, TN Coverage Map
Dyersburg WWH30 162.500 1000 MEMPHIS, TN Coverage Map
Hickman WXN74 162.500 1000 NASHVILLE, TN Coverage Map
Jackson WXK60 162.550 1000 MEMPHIS, TN Coverage Map
Knoxville WXK46 162.475 1000 MEMPHIS, TN Coverage Map
Lafayette WNG631 162.525 1000 KNOXVILLE/TRICITIES, TN
Lawrenceburg WWF84 162.425 1000 NASHVILLE, TN Coverage Map
Lobelville KWN52 162.525 1000 NASHVILLE, TN Coverage Map
Memphis WXK49 162.475 1000 MEMPHIS, TN Coverage Map
Nashville KIG79 162.550 1000 NASHVILLE, TN Coverage Map
Shelbyville WXK63 162.475 200 NASHVILLE, TN Coverage Map
Spencer WNG629 162.450 1000 NASHVILLE, TN Coverage Map
Vale KHA46 162.450 1000 NASHVILLE, TN Coverage Map
Waverly WXK62 162.400 1000 NASHVILLE, TN Coverage Map
Winchester WNG554 162.425 1000 NASHVILLE, TN
edwftx
162.475 NWS Norman OK - Wichita Falls Tx Transmitter
Jackson County,Oklalahoma
rdale
Lansing, MI
"162.475 NWS Norman OK - Wichita Falls Tx Transmitter"
1) Not the same freq as what he heard
2) They do not ID as coming from Jackson
INDY72
Indianapolis, IN
You must not have been scanning the actual WX freqs,... The 7 freqs don't include 162.4500..... they go .400, .425, .475, .525, and .5500 for MS transmitters. The only .450 I see listed is Vale,.. out of the Nashville Office, Spencer, out of the Nashville Office, and Centerville, out of the Nashville Office. You may have heard Jackson mentioned as part of the surrounding areas weather conditions, such as Jackson, TN, and for long range conditions, Jackson, MS.
Orrr under special situations, they might have originated a forecast from the Jackson, MS Office.
INDY72
Indianapolis, IN
As I stated, .450 is not a valid MS Transmitter freq. I also listed the TN ones that are .450..... And as stated, for the forecast to be originating from the Jackson, MS NWS Office, there has to be special circumstances. Vale is listed as originating from Nashville, TN NWS Offices.
slatescan
Hendersonville,TN
Thankis vale tranmetter it is b/.c last night i8t came in again and heard a met of paris i did hear the west tn seve weather outlook on thhere also thye mountgumey co tranmatter came in last night. so i had ducting to the north at 5 pm last night MILF how about a dx rpoerrts here on RR like scan masss has sure lindsey will try to work that into the site (lindsey great job so far)
