rdale said:That's how the latest ones work.
well that confirms it is a bug in the 396 firmware.
slicerwizard said:0 is just a convenient shorthand for 10.
Sounds more like a feature. And may not be possible to be fixed with current hardware...slicerwizard said:Still waiting for this firmware bug to be fixed:
If the AC power drops for five seconds (which happens a lot around here as they fight a losing battle to maintain our 30 year old lines), the firmware ignores the fact that the battery voltage is over four volts (e.g. fully charged) and starts a full 14 hour charge cycle.
...that confirms nothing. It just menas that they changed it.TedTed said:well that confirms it is a bug in the 396 firmware.
Cooking batteries is a feature? I have to wonder why you think it might be unfixable, since the A/D converter has more than enough resolution.b52hbuff said:Sounds more like a feature. And may not be possible to be fixed with current hardware...
What are you getting at? What does that have to do with cooking batteries?If you'll remember the battery voltage indicator was an 'undocumented feature'. I wonder if this was intentional?
We aren't talking about knowing when a charge is done. We're talking about not initiating a charge (or maybe pro-rating it somewhat) when the batteries are sitting at about four volts UNDER LOAD.I'm no means a battery expert, but my understanding is that some of these charging algorithms require very careful measurement of battery voltage in order to know when battery is done charging. Perhaps the voltage sensor in the uniden isn't that accurate.
We don't expect just-the-right-charge out of a scanner. We just want some intelligent design. It won't charge alkalines, even if you tell it to, but it will charge fully charged cells.check this out:
http://www.thomasdistributing.com/maha-mh-c801d-details-win.htm
It features eight analog-to-digital converters with precision resolution at 0.001V (that’s one thousandth of a volt) per battery delivering just-the-right-charge.
Still waiting for all that gloom and doom to take out my Pro-32, Pro-43's, 245, 246 and 396. All those Unidens out there with custom battery packs - where are all the horror stories? Odds are far higher that I'd eventually damage the battery door doing daily battery swaps.Anyway, as has been mentioned many times before why treat a $500 scanner like a $50 battery charger? Why take the chance of a battery failure ruining the unit? Or even worse (and more probable), the slow death of extra heat from the battery charging?
Eh? The manual says nothing about what it does with batteries that don't need a charge. They carefully avoid mentioning this problem and Paul's official response has been that charging fully charged cells for an additional 14 hours will not harm them, even though enough of us have already seen what the true effects are....anyway, this is more like a feature and not a bug... The 14hr charger works as advertised in the manual...
slicerwizard said:Still waiting for all that gloom and doom to take out my Pro-32, Pro-43's, 245, 246 and 396. All those Unidens out there with custom battery packs - where are all the horror stories? Odds are far higher that I'd eventually damage the battery door doing daily battery swaps.
So do you want defects with this model fixed or not?
Because sometimes I want systems to be scanned without assigning them to a key. In fact, most of my systems are not assigned to a key for the reason below.b52hbuff said:...that confirms nothing. It just menas that they changed it.
Which is why I was saking wolter why he was removing sqk's in the radio? If you're trying to do a 'temporary' lockout. You could easily assign multiple systems to a single SQK and simply disable systems you're not interested in. No need to remove the SQK assignment.
I've seen enough (older) radios with the battery doors held on with tape. Plastic tends to get brittle as it ages. Sooner or later, instead of bending, the snaps just break.b52hbuff said:Where are the horror stories about battery doors being damaged?
http://www.radioreference.com/forums/showpost.php?p=203969&postcount=9
slicerwizard said:I've seen enough (older) radios with the battery doors held on with tape. Plastic tends to get brittle as it ages. Sooner or later, instead of bending, the snaps just break.
Not sure what point you're trying to make with the link - the author indicates that NiMH cells are quite safe, with the most likely failure mode being a defective rapid charger. And scanners don't do rapid charging, so??
slicerwizard said:when a voice comm drops and the scanner starts the talkgroup delay timer (I use two seconds to catch replies), the scroll knob does nothing - you can't get off the talkgroup.
