Dear Forum,
I am in the process in getting ready to order a Uniden Digital 396 scanner, with the RH96 remote head. I have a few questions I would like to clarify before I make any purchases. The scanner will be placed in my center console of my Ford Expedition while in use in the vehicle. I will mount a clip on the side of the interior console for the scanner to be mounted to while mobile. I will have a hole-mount monitor antenna from Larsen (Must have Black in color) on the roof. I will be monitoring anywhere from 37MHz to 900MHz. I have no clue on which adapter to use for the co-ax to scanner, or if there is a crimp on adapter the will go directly into the scanner. Should I use solid center, or braided center co-ax? All the power, antenna, and data cable will be run into the console as well. The RH96 head will be mounted just below the A/C control in a void area. I just want to make sure there are no gimmicks that I am going to have to deal with regarding the aforementioned scenario.
So in summary:
1) Solid or braided center co-ax? Does anyone have a certain brand that is better for scanners?
2) Is there a crimp-on adapter that will work with the co-ax I will be using?
3) Have there been problems using the RH96 with the Uniden 396T or XT?
3a) Will the 396XT even work with the RH96?
4) Anyone used this antenna?
Thanks in advance for any information.
Sincerely,
Cowand
So in summary:
Sincerely,
Cowand
