Uniden 396t V3 Update Bug ????
Saint
Fort Erie Ontario Canada
I also am seeing some difference with cc only searches, in the 800.0000 MHz
band
#I'm doing a cc only custom search and the scanner takes a long time to lock
on a EDACS Standard control channel, the control channel I listen to is over
5 bars strong.
#2 The scanner flashes that the system is a LT System and it's a EDACS
Standard system.
#3 not seeing any I'DS coming up or any audio
#4 also the signal strength meter on the scanner flashes to tell me that the
signal is 5 bars to 0 bars, like the priority feature is turned on or Close
Call is turned on, also this happens when cc custom searching a Motorola
Type II SmartZone, System Voice: Analog and APCO-25 Common Air Interface in
the 140.0000 MHz band
Steve
