jonlwright
Hi everyone. I have been updating my Uniden 780 xlt for the new UCAN reband. I though I was successfully trunking DCSO but it doesn's seem to work as well as it did prior to the reband. This may have something to do with preveous threads of creating a "Custom Band Plan for Rebanded Systems?"
Does my 780 XLT need a new band plan?
This is what I have found on the custom banding for the 780 xlt:
Your BC780XLT has a build in bandplan. This means that when you enter a new frequency into your scanner the mode and step will be selected from a pre-programmed list.
For your convenience, ARC780 also has a build in bandplan.
When you enter a new frequency in the software the mode and step are automatically selected.
You can easily change the software bandplan.
The zipfile you downloaded contains an example custom bandplan called 780plan.dat.
How can you use and change a custom bandplan?
Copy the file 780plan.dat from the zipfile to the directory where you installed ARC780.
Open 780plan.dat with a text editor.
The default file looks like this:
FR25 MD2 ST0
FR88 MD1 ST6
FR108 MD2 ST4
FR137 MD3 ST0
FR146 MD3 ST2
FR174 MD1 ST5
FR225 MD2 ST5
FR400 MD3 ST2
'mode: ( MD ) 0=FM 1=WFM 2=AM 3=NFM
'step: ( ST ) 0=5.0 1=7.5 2=10.0 3=12.5 4=25.0 5=50.0 6=100.0
Every line contains a frequency, mode and step.
Example: a frequency of 140.000 MHz will get mode 3 ( = Am ) and step 0 ( = 5 kHz).
If you like to add a frequency start point of 138 MHz with mode AM and step 100 kHz add the following line:
FR138 MD2 ST6
A line must contain a frequency, mode and step. You must use FR, MD and ST.
Save the file as 780plan.dat and restart ARC780.
In the software setup select 'Custom Bandplan'. ARC780 will now use your personal bandplan.
The bandplan file can contain a maximum of 50 lines.
You don't need to sort the frequencies. Just add or remove lines with a text editor.
When you use a custom bandplan please make sure that you use Advanced Frequency Upload in the software setup!
This above information does not seem to relate to the info provided by qlajlu. I'm not sure where to go from here. Any ideas?
FR25 MD2 ST0
FR88 MD1 ST6
FR108 MD2 ST4
FR137 MD3 ST0
FR146 MD3 ST2
FR174 MD1 ST5
FR225 MD2 ST5
FR400 MD3 ST2
FR138 MD2 ST6
