Uniden antenna for the car
chadbyoung
Austin, Tx
I found this antenna on the Uniden website:
BATG0521001 - Mobile mounting antenna for scanners. Replaces AT002
Has anyone used this antenna before? How well did it work?
Dubbin
Findlay Ohio
Its doesn't work very well at all. All it is is a wire with a bnc connector on one end.
freqs
warren michigan
its ok but not the best the bc 350 c comes with one from factory
CLTX11
North Tx
That almost is identical to the one they ship with the BCT-8.
I used it once when I first received the BCT-8, that was years ago.
As far as working good with CB, it doesn't work well. You will be able to pick them up but not far at all. I wouldn't waste the money on it personally.
popnokick
Northeast PA
I used one of those for awhile in my car and it was 1x worse than an AM-FM scanner antenna coupler, and 2x worse than the Tram 1199 glass mount antenna I currently have. The Tram 1199 DOES receive CB within about a 5 mile radius. Best is to do a permanent mount on the vehicle. But if you can't, through the glass is the next best option. Here are some cautions re: glass mount antennas -
https://forums.radioreference.com/scanner-receiver-antennas/353846-glass-mount-antenna.html
Sirzep66
Kennebunk Maine
In my SUV I have a permanent Mount wide band antenna.. The suction cup one we are talking about I used as a Base Antenna.. In the vehicle it Super Sucks. Came with my BCT12. Thanks for the links.. Will check them out later...
Sirzep66
Kennebunk Maine
I'm in Maine... 150 ish for most all transmissions. I'm not trying to promote the antenna.. Just when I used it for that time.
