Uniden BC125AT Setup
RadioGuy3007
Hello,
I have a BC125AT and below is some pictures of the setup. If I wanted to get other towns around me, what outside antennas can I purchase?
RonnieUSA
Rowan County,KY (Morehead)
Hello,
You have a problem, that scanner will Not work with that department, or any scanner as far as that goes, because it's Encrypted .
Here is a link for where You live>> Morton County, North Dakota (ND) Scanner Frequencies and Radio Frequency Reference
Looks like most everything in your count is Encrypted, so what do You want to hear?
Good Luck
RadioGuy3007
Blackink
Central Vermont
I'm curious..
I can hear the channel thats shown.
What exactly are you hearing on that channel? Actual conversations?
I'm assuming you're talking about the channel that is in the display of your scanner, 155.3100?
According to the database here and what RonnieUSA is telling you, that channel IS encrypted.
Copied from the RR database: Description-Sheriff's Dept X 3 - Encrypted.
