Actually that radio is much more likely to be a 245 then a 235 - the 235 could not be programmed with a PC, as mentioned before.
Apart from the horrible Scancat Lite Plus, I rather doubt that there's any program out there under current development that supports this radio any more. Probably the best of the lot would be Scan Control; I *think* it's still being supported, though not actively developed (I keep on hearing random notes about this...). The Senss software is another option
One thing to keep in mind is that with Win 8.x, many of these older programs might not run at all. I know Scan Control ran under Win7.x, but whether that, or the Senss software, will run under Win 8.x (or Win10, for that matter) is unknown.
You will also likely need a USB-serial converter; the USB-1 isn't rated to run with this radio, so you might be better off with an off the shelf solution. This article from our wiki goes into great detail via links about some of the pitfalls (and some solutions) for Win 8x issues...
Connecting scanners via USB - The RadioReference Wiki
And this article also covers some of the other legacy software for this radio...
Uniden Legacy Software Support - The RadioReference Wiki
There are, unfortunately, no programs I know of that will load data from our database. Scan Control used to have a utility for this, but the database has long since changed format, and I doubt it would work anymore.
If someone were to come up with a 245 solution that included web imports, it might have some popularity, as there's still a number of these radios out there...Mike
