Uniden BC23A 15 Watt Amplified Communications Speaker With USB Power
JASII
Memory Capacity
I have a Uniden BC23A 15 watt amplified communications speaker already. Can I power it via USB power with a KUNCAN Dc 5v to Dc 12v Converter Step Up Voltage Converter? It looks to me like it should work because the BC23A manual lists Power Source Voltage DC13.8V 1.5A (2.0A fused). The Kuncan lists Output: 12V 5.5*2.1mm dc connector; Max current: 2A. The biggest concern I would have is making sure that my USB power source gives me enough power. Has anybody here tried this yet? I use an Anker 48W 4-Port USB car charger in my vehicle which gives 2.4A max per port. I assume that I will come up short, since the speaker is listed at 15 watts, but the Anker only lists12 watts. Could I use two of the USB converters to get the current up to where I need it to power the BC23A?
https://www.anker.com/products/A2312011
https://www.uniden.com/automotive/c...C23A_15_Watt_Amplified_Communications_Speaker
https://www.amazon.com/KUNCAN-Converter-Step-Voltage-Dc5-52-1mm/dp/B01ID90K4A
SteveSimpkin
Lancaster, CA
Probably not. Tying the outputs of two switching power supplies together is probably not going to do what you want. Keep in mind that the USB voltage output is nominally 5 volts. 5 Volts at 2.4A is 12 Watts of power. The specified power consumption of the BC23A speaker is 20.7 Watts (13.8V and 1.5A) max. If you assume the 5-12V converter is 75% efficient, you will need a 5V input current of around 5 Amps (about 25 Watts).
