Uniden BC250D w/ E-Scanner...
EmpireSound
Does anyone else have a hanging problem with this program when trying to load frequencies? The program auto-configures and detects the scanner so why does it hang?
I did a search but no one seems to have a solution.
Suggestions are greatly appreciated.
AZScanner
Somewhere in this room. Right now, you're very col
Ummm... we need more info. What O/S? What type of serial connection (9-pin or USB adaptor)? Are you using a null modem cable as an extension? What are your settings on the scanner? Did you enable PC Control?
I get this all the time: "It doesn't work". That really only tells me that it doesn't do what you're expecting. Give us more details and maybe we can get it working for ya.
-AZ
EmpireSound
XP Pro, I use a 9 pin serial. I couldn't find a USB. I've tried setting the scanner at both 9600 & 19200 bps transfer rate.
In E scanner I paste the frequencies I intend to use from the upper D-base to the lower then I try to load them to the radio and it just hangs. The program itself just freezes as well as the scanner not the computer.
AZScanner
Hmmm...
Have you tried any other programs with any success? Odd that the scanner would freeze - I'd do a full reset on it and see if that helps (man+2+9 while turning the scanner on).
It's rare but I've heard of some scanners shipping with bad PC ports on them. You might be the unlucky recipient of just such a scanner.
Try a couple of free demo programs and see if they work.
Try: http://www.butel.nl/bc785/arc250basic.zip If that won't work either, then there's something wrong with either your scanner or your com port set up.
If it does work then you may need to contact Uniden support and see what they have to say about why the demo works and e-scanner doesn't. I personally can't stand e-scanner or arc, but some people like one or both of them.
-AZ
P.S. Not trying to start a flame war people... I know there's some real ARC fans out there who just got all pissy over that last remark. What can I say though, I write my own software for these things - everything else just seems hokey and/or lame to me. I guess I'm biased. :wink: Plus I like being able to add new features to my programs whenever I want. Can't do that with e-scanner or ARC!
EmpireSound
ARC250 actually works well. I don't know the deal with E-scanner but it came with the scanner. So I guess you get what you pay for. I got it to load once... but that was it.
Thanks AZ!
