tazluv690
NC_MAN
I ordered what you and mike posted on my comments.
Yes that’s exactly what I have both of them. ericseagroves@gmail.com thank you for all your help.Eric-
If the Amazon cable is the USA-19HS from Tripp-Lite, just PM me with an email address, and I'll send you that driver. That'll save you from searching the internet for that one. It's a 6 meg file.
Thanks Mike I just did what it said to do the BC 296D.Another tidbit - you need to set up your 296 before it will work with software. Here's the procedure...
Mike
I only have 3 USB ports on my laptop. And mine says com 3 with the Tripp cable not my scanner.ProScan supports your scanner for programming, and will work with Windows 10. There is a thirty day free trial, so you can download it & see if your cable will connect to the PC & ProScan.
When you connect the cable, and hear the 'ding' as Windows sees a new device has been connected, try going to the Devices link (under Settings), and see if it shows the scanner as connected. or if it says "unknown".
This is from the Devices screen on my laptop, and shows the port being used by my SDS200. I have it connected to the PC, with ProScan logging what is being received.
If the device manager is showing the Tripp cable, as Com 3, then see if the software will use Com 3. For the database scanners, you would see the actual scanner name when connected in Mass Storage mode. But on one of the non-database scanners, or a database scanner in serial mode, all you'll see in the device manager is the port. (I was thinking about the database scanners, with the scanner name, when I earlier suggested that you would see the scanner name, not just a port number.)I only have 3 USB ports on my laptop. And mine says com 3 with the Tripp cable not my scanner.
