Uniden BC796D Scanner
dmingus120
Stockton Calif.
I currently own a Uniden BC796D scanner. I'm having a problem with the squelch knob turning when I either turn off the radio or turn up the volum. I have tried to unstick the squelch knob from sticking to the volume knob but nothing I've done seems to work.
I would like to know if anyone has the same problem and what you did to unstick the squelch knob from the volume control knob.
Dan
wesct
Connecticut
Dan
generally, the problem is with a bent shaft. if you are careful, you can straighten it out.
good luck
wesct
jringo2u
my new one outa the box has this problem as well and its a major pain, for the price they should have at least your town and county programmed in
