UNIDEN BC796D WYOLINK HELP
WyoWabbit
Casper, WY
Trunking multi-table
Low High Channel MHz Base # of kHz
ID Channel Channel Offset Frequency Slots Step
00 0 4095 0 851.00625 1 6.25
01 4096 8191 4096 762.00625 1 6.25
02 8192 12287 8192 150.9925 1 2.5
03 12288 16383 12288 146.7775 1 5.0
04 16384 20479 16384 146.775 1 5.0
05 20480 24575 20480 153.5275 1 5.0
06 24576 28671 24576 149.37 1 5.0
07 28672 32767 28672 136.0 1 12.5
-Tom
WyoWabbit
Casper, WY
Low High Channel MHz Base # of kHz MHz TX kHz Highest
ID Channel Channel Offset Frequency Slots Step Offset Bandwidth Frequency
000 4095 0 851.00625 1 6.25 -45.0 12.5 876.6
01 4096 8191 4096 762.00625 1 6.25 30.0 12.5 787.6
02 8192 12287 8192 150.9925 1 2.5 0.9 12.5 161.23
03 12288 16383 12288 146.7775 1 5.0 -0.9 12.5 167.2525
04 16384 20479 16384 146.775 1 5.0 -0.9 12.5 167.25
05 20480 24575 20480 153.5275 1 5.0 -0.9 12.5 174.0025
06 24576 28671 24576 149.37 1 5.0 -0.9 12.5 169.845
07 28672 32767 28672 136.0 1 12.5 -0.9 12.5 187.1875
tyytor
Wyoming
what do you use for the ARC-250 software tho...? 1....2... and 3 ??
Hi the custom tables I used in rapid and middle of the state were 2, 3 and 4 with arc250, some sites have different tables might need to run unitrunker free ( not fast lane) to be sure on the sites for you, WyoWabbit has them all that i know about(y).
KC0CCB
Edgemont, South Dakota
hey could i send you my file..? i'm getting frustrated on the ARC-250 PRO
tyytor
Wyoming
Hi I need to find my file and how I set it up, if you pm me or post the file in zip format in this thread,
I know you have to go to trunking> settings, bank for that, then put the settings in and add the frequencies for that site, along with the group's, sort of complicated the first time after that not so much..
Also are you going to use it for fixed off Mount Pisgah (Newcastle) or mobile?
KC0CCB
yeah Newcastle and possibly Lusk too.. if possible... maybe mobile too and also fixed... okay on the ZIP FILE here
  • BC796D_08_21_20.zip
KC0CCB
tyytor
Wyoming
Hi ok give me a few days to get back so I can use arc250 pro and look at the file, if some one chimes in before Monday that's cool to.
