I just went through all the codes imported and got everything ready just to get a message that my scanner is incompatible.
I've been using it for 6 or 7 years on 396XT.I just went through all the codes imported and got everything ready just to get a message that my scanner is incompatible.
Yes. You MUST use a Uniden-supplied cable/adaptor.Its got something to do with the COM port settings.
Going to try another computer
do you now just plug the supplied cord to the scanner and then to a USB port?
Very helpful, thanks. I've had a BCD 396XT for almost 4 years, and programmed it (and controlled it) with Freescan with very little difficulty, but your tip will come in handy when I receive my BCD 996XT.well if you downloaded from RR, you have the correct com port.. Check the com port again, do a shift f1, then click the tab for com port setup, then click the tab for start auto. This lets Freescan select the com port that the scanner and computer will talk to each other. Sometimes the computer and Freescan lose their settings.
