Uniden bcd396xt cable communication error
firebell9137
Hi i have a uniden bcd396xt scanner. I have the cable and software freescan that i am using but auto detect and downloading from scanner wont communicate with my scanner. All drivers and com ports are working correctly. Any ideas anyone?
CT
This happens from time to time.
You may be able to disable the port in Device Manager and rediscover the port.
I'd power everything off and start from scratch.
Ronaldski
MI DB Admin
Bay City MI
I think this might have been a microsoft update deal? Take a look at my reply and fix-
hiegtx
Dallas, TX
Mines an unbranded kind from ebay
Has that cable ever worked? If it was working and recently quit, Ronaldski's 'windows update' comment may be the same issue.
If it has never worked, did you install the drivers for it?
Can you see where a Com port has been added via the Device Manager? Look at Doc's example in post number 2.
If Windows never created a Com port for the cable, and especially if Windows did not show installing any drivers, then the cable you have may not be correct. A correct cable, such as Uniden's USB-1 has circuitry in it to create a Com port when the cable is plugged into a USB port. The first time you plugged in the cable, Windows should have given you a message that it was 'setting up' your cable, and possibly asking you for the drivers. If none of that occurred, and you do not see a Com port in the Device Manager, then your cable may a counterfeit copy. Unfortunately, many of the cables listed on eBay, as well as Amazon & other sites, have fit that pattern.
ofd8001
Louisville, KY
Most of the cables I've seen had a "thing" in a housing which was the chipset. I do not see this and as such wonder if it is a true serial to usb compatible cable, particularly with the HXD chipset. (Which I suspect is why you are asking if it ever worked.)
hiegtx
Dallas, TX
Exactly correct.
While the "USB A" end, which connects to the PC is slightly larger, the cables that I've seen, that actually work, either have a significant housing inline, which contains the necessary chips, or else the USB A end is significantly larger than standard.
tvengr
Well Known Member
Baltimore County, MD
How old is your cable? This may have something to do with it.
Uniden USB-1 Cable
Important Windows 8 and 10 Information
The current Prolific Driver, as delivered through their web site and through Windows Update for Windows 8 and 10, will not work with older USB-1 cables that use the PL2303HXA chipset. To use these drivers you must have a current USB-1 cable that uses the PL2303HXD chipset. If your cable was bought before 2013 you need to buy a new cable.
  • Like
Reactions: wtp
hiegtx
Dallas, TX
Uniden USB-1 Cable
The OP does not have a 'genuine' USB-1 cable. It's a knockoff cable, purchased on eBay. But he has not answered my question as to whether the cable ever worked, and whether the correct driver was installed. There's been a number of cables sold on eBay, that are straight USB cables, without the embedded circuitry to function as a serial port. No idea whether that is the case with this one.
lebrunmn
Retired... Get off my lawn!
Hampshire County, WV
Uniden USB-1 Cable
I recently had a similar issue with my XT cable... Windows 10 update has pushed a driver that rendered the older cable incompatible, and I got some strange message telling me the cable was no longer supported and to call my supplier--whoever that may be...
Was able to update / roll back PL2303HXD driver to a previous version: Prolific PL2303 driver v3.3.2.102 (2008-24-09) Win8_x64_x86. That fixed the issue.
KQA726
Toledo
How about trying to use the original Uniden Serial cable, then use a Serial to USB adapter cable unit? Should work on Windows7.
