Voyager, do you even own one? It doesn't charge the batteries while the scanner is on, which sucks ***!
Overcharge? What is this the 90's? Their internal charger should have all these things built in, to charge the battery up safely and then shut off.
The scanner should work like a cellphone, you plug it in, it starts charging. It should also charge WHILE the scanner is on.
Do you want your cellphone to ask you whether you want to start charging it every time?
For those that don't give a crap about alkalines and never plan on using them in the radio, give us an option in the setting to turn off this stupid prompt!
Yes, I own one. In fact, I have one of the first ones. And from your post you don't appear to know much about electronics. So, here is a little bit of an education:
Doesn't charge the batteries when on: USB can deliver 500 mA MAXIMUM (while there are USB devices that CAN deliver more, you can't assume all USB devices do). It takes nearly that much to operate the scanner. It takes nearly that much to charge the batteries. So, if you can figure out how to get 1000 mA from a device that can deliver 500 mA without damaging it, PATENT that idea. I will wager good money it won't happen, BTW.
The charger should have all the protections built in: The unit requires 3-4.5V to operate. This pretty much mandates AA cells in series unless you want to change to a proprietary battery and incur the wrath of about 90% of the users out there. As the cells are in series, you cannot reliably detect a full charge of an individual cell. Even if you could, there is no way to stop charge one one series cell without stopping the charge on other two. If you can figure out how, PATENT that idea. I will wager good money it won't happen, BTW.
The cellphone issue was covered in the last paragraph. (I would wager your cellphone doesn't use AA cells unless you're using a DPC550 (which, ironically, IS a 90s device). But, phones don't use AA cells anymore. In fact, many of them don't even have user-replacable batteries. BTW, your cellphone doesn't consume nearly as much current as a scanner, so your charging while operating comparisons don't hold water.
Your alkaline comment makes even less sense, as you say you don't care about them and that's the ONE valid point you would otherwise have, as alkaline use is the one reason to not have the prompt. But, I know the scanner won't even try to charge alkalines, and it's quite possible it won't prompt when you use them. I'm not sure about this one, as I don't use very eco-unfriendly alkalines.
No charge for the Electronics 101 lesson.
