96dodgeram360
I recently purchased this scanner and I’m trying to get it set up properly… I live in La Grange Tx 78945 zip… we have P25 phase II here locally and I’m have an in and out issue… any help would be great thanks!
Don’t know what an “in and out” issue is but La Grange only has the FD listed in the Radio Reference database (RR) as a conventional system. The rest (PD, etc) are on the P25 system you mention. Since I’m not from the area I would suggest you swing by the local FD and inquire who may be running a scanner, their local scanner guru, and ask if they might help. That trunked system is large, meaning you don’t need to (and shouldn’t) install all of it. First, list what services you would like to monitor and ask the local knowledgeable guru. You can also log into the regional RR Forums, listed by state and ask for help there. Go to RR,, tap the Forums tab and scroll down to the regional groups, choose Texas and post a request for help.
I’ve set digital threshold to 5 but still on autoI’m sorry I wasn’t more clear the received departments mostly are cutting in and out while talking I can’t ever receive a complete broadcast
Full strength signalWhat is the signal strength?
There are three sites for the LCRA system in Fayette county. None are tagged as Simulcast.I’m sorry I wasn’t more clear the received departments mostly are cutting in and out while talking I can’t ever receive a complete broadcast
There are limits on file types & sizes as to what can be attached to a post.I recorded a video but I can not upload on here
I do have priority and close call enabled let me disable and try that thanksThere are three sites for the LCRA system in Fayette county. None are tagged as Simulcast.
If the transmissions are 'cutting in and out', is that 'cutting in and out' on a fairly consistent interval? There are three things that can cause a repeated, regular, interruption of your reception.
Priority is enabled
Weather Priority
and
Close Call.
Any of those three will cause regular, brief, interruptions in your monitoring. Did you program it your self, or did you order it pre-programmed from one of the dealers? Have you installed Sentinel? If so, look at your Profile in Sentinel. You can check there to see if any of these three items are enabled.
If you want to ask for help or information in the Texas Forum, do not start a separate thread. Instead, click on the Report link in one of your posts & request that your thread be moved down to the Texas regional forum.
If you will make of list of things you want to hear, I would be happy to assist you in your programming efforts. From what I am seeing in the RR DB, there are only three sites listed for your county on LCRA P25.
